Could not set the VLAN port interface state to either block or unblock as the VLAN port interface was NULL.
Check validity of the port and VLAN instance configured on the ring using the 'show erps' command
Error
Invalid input while setting VLAN-port interface state %vpif%
| Name | Type |
| vpif | uInt32 |
